Post by spyder9 on Mar 13, 2011 16:20:27 GMT -5
i have a 1973 shasta 12' trailer. it has a white walled bathroom with a hole in the floor for tolet and a water hookup, i look in the hole and its a wood bottom, how do i hook up a tolet ? thanks
Post by Atomic Addiction on Mar 13, 2011 21:08:47 GMT -5
I moved this question to it's own thread...
Post by Atomic Addiction on Mar 13, 2011 21:12:16 GMT -5
If you look down the hole and there is wood that isn't good. That means there is no Black water tank under the floor. There should be a fiberglass Black Water tank under there.
I am guessing there is no Black Water valve if you look under the trailer?
Post by spyder9 on Mar 13, 2011 23:04:05 GMT -5
i need to look under the trailer a little better, thanks
