Post by flyingham on May 1, 2011 20:33:02 GMT -5
Post by dawgpound on May 2, 2011 9:34:20 GMT -5
I found some aluminum tubing at my favorite hardware store. I also picked up a few stainless steel washers to go on each end of the aluminum tubing, in hopes to keep the aluminum tubing from being pushed into the siding or into the wings.
Post by blu26ovl on May 2, 2011 20:15:50 GMT -5
I found some nylon spacers in the specialty hardware bin at a local hardware store and put a stainless steel washer on each end like Ross did. When i got my camper the screws had been tightened down too much and sunk in the side of the wings. I took them apart and made a spacer from small plastic water supply line for your home sink and put in the wing then ran the screw through it to keep the wink from sinking in.
Brent in N.C.
Post by Gremlinguy on Jun 12, 2011 9:53:06 GMT -5
I mounting my wings today . Are the wings spaced off the camper so they sit on top of the driprail??
Post by Redwings on Jun 12, 2011 11:31:06 GMT -5
Ours sat on top of the drip rail on the back attachment point, but we needed spacers for the two forward screws to "lift" the wings to the same horizontal plane as the back attachment.
Post by Bob on Jun 12, 2011 12:14:41 GMT -5
pieces of a sink faucet riser pipe cut to the lengths needed. (the grey poly pipe that's 3/8th inch OD)
Post by 62astro on Jun 23, 2011 16:04:29 GMT -5
ditto potomac30
Post by shastahappy on Jun 30, 2012 8:53:34 GMT -5
Ace hardware had rubber bumpers shaped like a cork with a hole in the middle, that's what I'm going with.
Post by universalexports on Jun 30, 2012 9:00:21 GMT -5
our local Ace also has a black cabinet with fancy chrome nuts and chrome bolts and chromed spacers in various lengths.
Post by boandsusan on Jun 30, 2012 18:23:16 GMT -5
We bought thick nylon spacers at our local hardware store. The 3/4 inch long, were perfect to keep the wings outside/on top of the J rail.
