Post by blueskidoo on May 5, 2011 21:42:49 GMT -5
My Compact has a rock guard, but it is missing the pins that hold it open when it is parked. It has the ones that hold it closed when driving. I am currently using wire coat hangers, very red-neck of me What should I use to replace the missing pins? Thanks!
Post by Atomic Addiction on May 5, 2011 22:40:30 GMT -5
Is it a tube style support arm? If so I would say split cotter pins would work well. Most hardware stores should have them Brian
Post by blueskidoo on May 6, 2011 19:23:27 GMT -5
It is a square tubing, but I think those would probably do it. Thanks!
Post by Atomic Addiction on May 6, 2011 19:50:41 GMT -5
Post by dawgpound on May 7, 2011 6:24:30 GMT -5
Post by blu26ovl on Mar 20, 2012 19:48:31 GMT -5
My compact does not have an original rock guard but it has square tubing with channel inside that slides in and out. It has a threaded insert with a wing screw in it that you tighten down to lock rock open where you want it.
Post by cowcharge on Apr 8, 2012 23:15:33 GMT -5
Mine has wingnuts too.
