Post by universalexports on Jun 27, 2011 0:29:23 GMT -5
not sure where to put this, but, I was looking at moving my camper into my garage, where it is dry and I have a great heater to do my remodel this winter,,, but I have a problem, my camper is about 6 foot 10 inches, if I remove the wheels, axles, and springs, and my garage door is 7 foot.
anyone found an easy way around this???
I am thinking remove the wheels, axles and springs, and sit the camper down on 1/2 inch plywood with long wood dowels under it, to allow it to roll. then push it into the garage.
any ideas???
Post by Shutzee on Jun 27, 2011 6:57:30 GMT -5
Take the wheels off, lower the trailer onto the spring shackle bolts. We put 2 liter pop bottle caps on the bolts (slides easier). A little butyl tape inside the bottle cap will keep them in place while you lower trailer. Using the safety chain, have two people pulling the trailer in a zig zag motion, one person pushing on the alternate back corners will help. Once inside, you can put the wheels back on. We've been doing this for 3 years now. No damage to the trailer. Works great.
Post by universalexports on Jun 27, 2011 8:45:49 GMT -5
thanks, I get the whole zig zag motion, i've done that when I had to move my car trailer a few feet.
Post by mary1960 on Jun 27, 2011 13:28:37 GMT -5
Good luck ... can't get the little forester inside our garage for anything (and we tried everything) but the LoFlyte fits in there fine once we lower the tire pressure. Go figure.
Post by cowcharge on Feb 8, 2012 18:42:54 GMT -5
Can't get 2" out of the tires? Hmm.
Post by universalexports on Feb 8, 2012 22:18:25 GMT -5
Can't get 2" out of the tires? Hmm. Sorry, read my 1st post again, my camper is 6 foot 10 with the wheels axles and tires REMOVED! which means if it was setting with the frame on the ground it is 6'8" so I would have to have some dolly wheels or something that is less than 2 inches tall to slide it around on, or soap the floor and slide it on its frame. it's over 8 feet as it sits normally. but this is an old thread, I have since bought a carport for it.
jann
Post by jann on Nov 20, 2012 9:27:49 GMT -5
Go to harbor freight and buy the dollys for about $50 for a pair. Jack up frame remove wheel and lower hub onto steel dolly cradle. You could place a folded towel if you are concerned about scratching hub. And that should give you about six inches
jann
Post by jann on Nov 20, 2012 9:30:41 GMT -5
Also the cradles give you the ability to move the unit sideways if necessary. Make sure you inspect the steel cradles bolt attachments for the casters that they are securely tighten.
