Post by mom2abunch on Aug 20, 2011 13:18:24 GMT -5
Does anyone recommend to treat the wood framing or interior panels with a water sealant or finish to protect them from water? What would you suggest using?
I know there are issues with using treated wood and aluminum... So I am looking for suggestions. Thank you
Post by universalexports on Aug 20, 2011 13:26:41 GMT -5
Post by Bob on Aug 20, 2011 17:07:14 GMT -5
I painted the framing and plywood from the outside before I insulated and put the aluminum on. (home-built)
Post by Gone Kayaking on Aug 20, 2011 22:37:03 GMT -5
I also put water sealer on all my framing and the back side of the plywood before insulating. THere are many water based sealers out there, that arent' toxic. I used Thompsons cause it was on sale. Takes no time at all, it's cheap, and it could keep the rot away. Do it!
Post by mom2abunch on Aug 21, 2011 16:30:52 GMT -5
Thanks for all the advice. I was guessing it would be a good idea.
Post by blu26ovl on Aug 21, 2011 18:31:54 GMT -5
I also used Thompson's on all of my framing. Since I was painting my new paneling I primed both sides with oil base primer before installing. I also painted the wood framing all around the bottom edge with oil base paint and undercoated the bottom of the camper. l
Post by elewayne on Oct 25, 2011 20:11:50 GMT -5
Thompsons or something like that may help. Most finishes won't stop rot but might slow it down. Wayne
