Post by shastatexas on Dec 31, 2011 19:40:07 GMT -5
where can I find the crank and parts for one of the outside front windows on a 1967 Aeroflyte? We have the windows (po installed ac there) but apparently po did not keep hardware, just windows. Does anyone know what other models/years were used on?
Post by vikx on Jan 1, 2012 0:09:34 GMT -5
Do you have a photo of the front of the trailer and the windows? It depends on the size of the rough opening what type of window might have worked. I've had two 68s and a 69 with different windows.
The 68 Starflyte has a large window in the middle with a pair of 2 pane jalousies on either side. I have photos of the cranks on that trailer.
Post by shastatexas on Jan 1, 2012 8:21:09 GMT -5
Thanks. I wil try to post a pic today. I have thr solid window in the middle with the crank windows on each side. One of the crank windows is complete and in working order. I just need the parts for the other window.
Post by shastatexas on Jan 1, 2012 17:54:51 GMT -5
I have attached a picture of the complete front end window, there is a plain window in the middle then there should be another one like this on the other end. I need the hardware shown. Thanks. Attachments:
Post by vikx on Jan 2, 2012 0:13:00 GMT -5
Try Fletcher's for the cranks. They have lots of parts: vintagekingpins.com/ These windows are fairly common; just a matter of tracking them down. Good luck!
Post by shastatexas on Jan 2, 2012 8:14:27 GMT -5
Thanks l hadn't found that site.
