Post by harrican on Apr 10, 2012 19:53:19 GMT -5
Post by universalexports on Apr 10, 2012 20:17:57 GMT -5
I think that, (although a little more work) would be a better way to do it, rather than bolt it permanently in a window. neat idea!
Post by harrison429 on Apr 11, 2012 5:11:03 GMT -5
Hey, that's just like my temp set up! The po had built a wooden box to fit over the front window. It slips up under the drip cap/eyebrow and hangs on the window frame. He used a couple of screws to keep it all from falling off. I didn't like the idea of the window frame supporting the weight so we are using a table beneath the a/c unit sort of like the link shows. With the a/c going through the front window (screen and all) the air circulates itself because of the shape of the trailer. We've also used the set up on the side window though it wasn't as 'sealed' with the wooden box because the side window is smaller than the front but it still worked. We don't carry the extra weight or lose any storage space which is important in the compact. We'll be camping again in 2 weeks...I'll take pix then.
Post by boandsusan on Apr 14, 2012 11:19:37 GMT -5
That`s a neat idea! I think it would be great for long weekends but I think a bit too much work for say a 50+ female ,if she was traveling and had to set it up every day.
Post by lopo on Apr 14, 2012 12:01:39 GMT -5
Susan has a point. Also, notice that the windows are jalousie style so the a/c unit can sit much closer to the screen than with the awning style windows like my '72 Compact has. The unit would have to sit like 7" outside the window.
Post by 65callie on May 5, 2012 14:42:29 GMT -5
harrican: Thanks for posting this! Hubbie is building one like this today. I hear grinding, cutting, welding, and a little cursing (normal construction sounds around here ). I will post pics when it's finished. So far it looks great.
Post by harrison429 on May 5, 2012 17:38:25 GMT -5
So here's a pic of our temporary a/c set up. Eventually we'll do something permanent like in the link and like 65callie is talking about but for now it's worked great. We just open the jalousie windows and she stays nice and cool...even while baking in the sun at Stone Mountain (this pic). Note the clever way I used the 'flower box' into tricking your eye into not noticing, the a/c unit, the box support, the table hahahahahahahaha ;D Attachments:
Post by LittleVintageTrailer on May 5, 2012 18:01:04 GMT -5
That is pretty clever! Also I am tickled to see the color of your trailer. It gives me an idea of that that color looks like. Is it Coral?
Post by 65callie on May 5, 2012 18:41:00 GMT -5
You should drape a tablecloth over the table under the AC box ;D
Post by harrison429 on May 6, 2012 7:55:38 GMT -5
Thanks LittleVintageTrailer...the actual paint swatch calls it Red Grapefruit (glidden) and that is what the color actually looks like in person however, sodashoponwheels says hers is a '56 Ford Coral and we think it's the same color because the awning fabric we both have matches our trailers perfectly! 65callie-I tried the tablecloth over the table trick before I decorated the support box and all it did was draw attention to the ugly support box. hahaha Perhaps it will be permanently fixed (like this thread and what you're doing) before camping resumes in Autumn, you know, when we won't need the a/c.
Post by vikx on May 7, 2012 0:35:37 GMT -5
This is so cool! Thanks for the pictures.
Such a pretty PINK trailer.... running away really fast....
Post by 65callie on Jun 20, 2012 17:27:54 GMT -5
We copied this idea and it works great! Hubby welded the platform at an angle onto the support rod so the A/C would drain properly. The jack under the rod isn't necessary at all, after the wood box is in place it is very firm, no wiggling. I was so worried it would fall, my Hubby put the jack under just to calm my worries, in other words to shut me up . We got a 6500 btu with a remote. Didn't need one that large but couldn't find a 5000 with a remote. Having the remote allows us to leave the window screen in place. We never would have survived a week in Florida without it! Attachments:
