Post by Atomic Addiction on May 2, 2010 21:11:00 GMT -5
Vikx-
This is a window focused question so I tossed it over here in the Window section...
As far as your question... I may have a few on my card that I can try to pull up. I will post them if I can in the next few days. If not I will take some for you.
I think you are suppose to set the glass in a bead of vulkum and or putty tape. The outer rubber seal isn't the best to keep the water out by itself.
Post by joek on May 3, 2010 23:22:59 GMT -5
I used the gasket that VTS sells: www.vintagetrailersupply.com/Hehr_Standard_Glass_Seal_p/vts-195x.htm as well as the aluminum colored silicone: www.vintagetrailersupply.com/TremPro_644_RTV_p/vts-566.htmI put the silicone between the glass and the gasket. Then used 3/4" wide strips of 1/4" Birch plywood stapled into the framing to hold the glass in. I put a lot pressure towards the glass before stapling the ply strips in place. Let it dry, then trimmed off the silicone that squeezed out with a razor blade and a steady hand. This has lasted one heavy winter rainy season with no leaks and no window drip caps to protect it. I can't say it won't leak next year, at least not yet. I can take and send pics if needed. Let me know.
