Post by vikx on Jul 17, 2012 13:28:08 GMT -5
Hello all, just wanted to post the correct color code for 7 way connections.
The colors are stamped into the 7 way plug and receptacle. The code below is used for all 7 way wiring.
White=Ground Black=Hot Charge Line Blue=Brake Hot Green=Running and Tail Lights Brown=Right Turn Red= Left Turn Yellow or Center post= Aux
If you are switching from 4 way flat, the code is DIFFERENT:
White=Ground Green=Right Turn...... 4 way Green goes to 7 way Brown Brown=Running Lights..... 4 way Brown goes to 7 way Green Yellow=Left Turn..... 4 way Yellow goes to 7 way Red
Many vintage trailers did not follow the universal wiring code, so you may need to test each wire to see what it does. With a Good Ground, put 12 volts to each wire to see what works.
Note: eTrailer comes up first in any search for wiring codes. The 7 way code on the site is WRONG.
DO NOT USE eTrailer's code when wiring a 7 way system.
Hope this saves some of you headaches when doing tow wiring...
Post by 65callie on Jul 17, 2012 18:08:25 GMT -5
Thanks Vikx!
Post by Bow_Tied on Jul 17, 2012 18:47:48 GMT -5
So, the brown and green are reversed on Shasta trailers? This is the diagram I am used to, matches my truck. But rather like this?:
Post by dawgpound on Jul 17, 2012 20:31:33 GMT -5
Hey Ron,
The diagram that you show is the way I have all of my trailer wired and all of my tow vehicles.
Ross
Post by schweetcruisers on Jul 17, 2012 21:41:09 GMT -5
VIKX-thank you for this, when I googled the wiring diagram everyone seemed to have a different chart and most just used the e-trailer diagram.
Also the 7stud Junction box made by Phoenix is also mis-marked and the color coded wrong. Just an fyi!
Post by vikx on Jul 18, 2012 2:28:23 GMT -5
My Shastas are wired as described: 68 and 69 LoFlytes, 58 Starflyte, 57 Deluxe and two 57 1500s. One did substitute black for brown on the RT...
I posted on the 7way plugs and receptacles. The colors are STAMPED in the plastic on most 7 ways.
Green is running lights. Brown is Right Turn. This has nothing to do with vehicle wire colors.
The universal 7 way Trailer color code is used on almost all trailers heavier than 1000 pounds. Just makes sense to follow thru and think: Brown is RT, Green is Running Lights, etc .
eTrailer errors: 1. There is no orange wire; normally this is a back up light or spare wire and yellow 2. Brown should be RT 3. Green is Running Lights. 4. RED is Left Turn
A person could easily wire as eTrailer recommends to work. I like my 7 ways to work with all trailers; therefore follow the Universal code. Why not?
I'm curious If the powers that be are trying to resolve this. It would be good to change the code for 7 ways to match 4 ways, 6 ways, etc. Wouldn't that be too easy??
This has caused so many so much trouble. Just trying to get it sorted out to make it easier. Thanks all, for the replies.
Post by vikx on Jul 18, 2012 2:37:04 GMT -5
NOTE: I'm talking about 7 way blade connectors. The older 7 way round connectors are another kettle of worms...
Post by harrison429 on Jul 18, 2012 15:26:20 GMT -5
as you know vikx, after trying etrailers way which did not work we finally found the right site which made our lights work which was also confirmed by you (and which prompted your post) thanks oh trailer resto guru!
Post by Bow_Tied on Jul 18, 2012 22:28:30 GMT -5
Ross, which diagram, I posted two?
Post by vikx on Jul 19, 2012 1:04:42 GMT -5
The wiring I do is the 2nd diagram.
I should say here, that many trailers have odd color wiring and it is not the color that matters. It is the position of the wires in the 7 way that is important. In other words. You can use a pink wire in the green slot, as long as it runs the tail/clearance lights.
Hope that makes sense. The "green" slot should be tail/clearance lights.
Never trust a trailer wire color to be correct. It's easy to test with a 12 volt power source to see what wire runs what.
Post by bagpipeswest on Jul 30, 2012 22:20:05 GMT -5
I started reading the 7 way thread and it realy threw a red flag up for me. I had my 72 GMC wired with a 7 pin to tow my 29' prowler. it works great. I'm at the point where its time to wire the plug (trailer side) on my rainbow. The cord I bought from vintage trailer supply matches up.( Right colour, right position) The box I bought at princes auto however is all wrong.
By reading this post and going out to my big trailer, I tested the lights by putting a wire from the black (hot) wire to the other wires. So ,, Black and green (running lights) black and red ( left side turn and brake) , Black and brown (right side turn and brake) if your batteries are in the lights you test will light up
I used a meter for black and white 12v and did not test black and blue (brake controller)
Thanks for having this thread. It saved me from a big hassel
BM
