Post by seizure66 on Sept 26, 2012 10:15:17 GMT -5
I have a compact with the tongue stamped ES19442PA1722. This seems odd to me. What say you Shasta pros? The reg. says 1970 and I believe that to be Waaaaay off! Attachments:
Post by vikx on Sept 27, 2012 0:08:19 GMT -5
Looks older to me... Maybe early 60s?
Post by safetybruce on Sept 27, 2012 1:59:59 GMT -5
Wow, what a sweet Compact! It can not be newer than 1963, and I'm thinking more like a 1960 because my 1961 has a running light on the curb side in front of the door, and yours does not have one, and I see no trace that one was there...Ross will probably let you know for sure he is our SME...in the meantime, remove the mirror on the closet door...it will have a stamp on the back telling you when it (the mirror) was made that will let you know pretty well what year it is.
Post by Deleted on Sept 27, 2012 4:44:27 GMT -5
I'd be guessing that somewhere in its history, someone registered it with no paperwork for a transfer, and the serial number is one that was assigned by the DMV somewhere, and may have happened in 1970. That is one sweet Compact. Definitely early '60-s as they went to the "toaster" shape somewhere around 1965.
Post by desertman on Sept 27, 2012 7:41:51 GMT -5
More photos will help. But as to the clearance lights my 67, 13' doesn't have front clearance lights. It does have a stove vent in front of the door.
Post by dawgpound on Sept 27, 2012 16:45:40 GMT -5
Are you sure that it is "ES" or could it be "FS"? Reason being, the "FS" Vin#'s had the second set of numbers that began with the "PA" prefix. This would make your Shasta a 64'. These were Northridge Shasta's, as well.
Based on the other "ES" VIN, you have a 63' Shasta, born in Northridge, California.
Hope this helps.
Post by safetybruce on Sept 27, 2012 21:42:12 GMT -5
I'm sticking by my guess that it is a 1960! NOT...Ross is the man!
Post by mleastland on Nov 25, 2012 14:35:41 GMT -5
Evidently Ross is the vin guru maybe you could help with mine. After a little wire brush work I found this T12961. Any help would be greatly appreciated. Been eyeing it for a while in this driveway on the way to work. I stopped the other day and she said I could have it if I got it out of her driveway I think its a early 70s compact. Hasnt been road legal since 86. Having trouble finding wheels and tires so I can move it.
Post by paigenmarc on Dec 11, 2012 10:57:17 GMT -5
What a cute trailer! I agree with the 1960 ish date.
Mark
1961 Compact
Post by Mark on Dec 11, 2012 11:17:40 GMT -5
This is a 1960; the 61 would have an additional running light in the upper right.
