Post by purplepeep on Sept 29, 2012 9:32:28 GMT -5
The vin # is P1534
What does that tell us?
Thanks in advance!
Post by dawgpound on Sept 29, 2012 9:50:42 GMT -5
What Model do you have?
Post by Deleted on Sept 29, 2012 9:58:24 GMT -5
The "P" character designates the unit was manufactured in the Leola, Pennsylvania plant, which is quite common for the units you would likely find in NY state. The remaining digits are a sequential number of built units. I am not totally sure if there would have been a "batch" of one particular model that were run in order, say for example, the Airflyte models in a run of 2000 units being numbered in the 1000-2999, and another model say Compacts run in a batch in another grouping, say 3600-3700. There does not seem to be a definitive answer to that, nor is there a for-certain way to tell the manufacture date, or model from the serial number.
Board member Ross has been accumulating a database of numbers and has been generous enough to share his knowledge of where your number should fit with regard to a date of manufacture. I am sure he would be pleased to add your s/n to the database as well!
Post by purplepeep on Sept 29, 2012 21:17:38 GMT -5
Thank you both! It's a Airflyte. I'd love to know the year.
Post by dawgpound on Sept 30, 2012 11:35:22 GMT -5
Your Airflyte was born in Pennsylvania, as Chris mentioned, in 1963.
Post by purplepeep on Sept 30, 2012 13:43:24 GMT -5
Thank you so very much Ross!
Post by dawgpound on Sept 30, 2012 16:28:48 GMT -5
My pleasure!
