Post by supermerle on Jan 3, 2013 16:27:22 GMT -5
I have a corner on my rear window thats come undone? Has anybody welded their's back or can you use JB weld or ? I've got a mig welder but I don't have any wire to weld aluminum with or the right type gas (argon)? Any suggestion?
Post by pathfinder3081 on Jan 3, 2013 16:34:36 GMT -5
Alot of people on here fill the gaps and mend in the cracks with JB weld. I have not used it on my trailer as of yet. (But I have some..just in case.) If the frame is out of the unit, the glass removed? I say weld it! But you better have your game on. I imagine that one could burn through in the snap of the finger. I'd take it to a local shop and let them mend it. They probably wouldn't charge more than $20.. Then you'll know that it's done right. IMO
crunchy
I cut.
Post by crunchy on Jan 3, 2013 17:19:28 GMT -5
Post by desertman on Jan 3, 2013 18:37:49 GMT -5
I would take it to a shop and have it TIG welded. Having welded aluminum I can vouch for the fact that old,dirty, thin aluminum requires experiance (lots of trial & error). JB will work if you go at it from the back side (wont show) . Otherwise it will be off color.
Post by supermerle on Jan 3, 2013 18:59:07 GMT -5
The window is out so I can reach the back side? I think I'll take it to a shop and get it done right. Thanks everybody
Post by supermerle on Jan 11, 2013 18:16:14 GMT -5
Well, my wife first cousin has a big company that fab things and he was able to fix me up on welding the corner of my window. So, everybody is happy happy happy!!!!!!!!!
Post by supermerle on Mar 15, 2013 8:37:56 GMT -5
Here's a little up-date and picture. Here's my window that I had welded. It's the upper right corner but its hard to see under the eyebrow. The whole ordeal started due to the need of having an A/C in Arkansas for camping during the summer-time. If I ever install a different A/C I will be able to return the rear window to original spec's. Attachments:
