Post by Deleted on Jan 26, 2013 20:07:18 GMT -5
Recently there have been discussions regarding the dimensions of the dinette table, as well as the construction of a dinette to replace the gaucho setup in the older 16SC models. I'm putting this here in the hopes it will help with these questions. It is probably too much information, but if it isn't enough let me know, the least I can do is help.... I don't know if this is going to be the same across the board for all the older models, but here is the dinette table from the '64. The overall table measures 36" X 30". On the inner end it has the one corner (toward the curbside) rounded off with what appears to be about a 4" radius corner. The other corner (streetside) is cut off to allow easier passage around it into the seat. The cut starts at about 30" from the wall and ends at about 26" from the far edge.
Post by Deleted on Jan 26, 2013 20:12:08 GMT -5
The underside of the table is framed with a rectangular frame of 1X2-s, centered across and situated at the wall-end of the table. It measures 23" X 33". The wall brackets are mounted to this frame. When the leg of the table is swung out to support it, the leg rests closely against the frame, although it is not attached to it.
Post by Deleted on Jan 26, 2013 20:14:11 GMT -5
On mine, the leg is mounted with an aluminum hinge, inside the edge of the frame, and has a hook (and eye screwed into the floor) to keep the leg from being kicked out from under it.
Post by Deleted on Jan 26, 2013 20:16:21 GMT -5
This photo shows the mounting of the wall brackets. They are all the way to the outer edges of the frame, and of course dictates the position of the wall-mounted brackets.
Post by Deleted on Jan 26, 2013 20:30:19 GMT -5
Post by Deleted on Jan 26, 2013 20:38:31 GMT -5
This shows the curbside seat frame in place. The "rear" part of the frame against the wall measures: Top rail... 40" Bottom rail along floor (at wall corner) .. 30-1/4" Two vertical slats on wall...7-5/8"
Post by Deleted on Jan 26, 2013 20:40:59 GMT -5
The frame is free-standing, as it was screwed into the wall frame through the paneling with wood screws. This is a look at the side of the frame that goes against the wall.
Post by Deleted on Jan 26, 2013 20:49:01 GMT -5
View of the bottom (footprint). Left of the photo is the end toward the doorway. The edge at the wall measures 30-1/4" long, edge near the table is 36" long, to the edge of the cutout at the base, for the support board at he corner of the front wall. Cross-slats all measure 22-3/8" long. A note: the one at the left end lays flat, while the other two are on edge, acting as the slides for the drawer underneath.
Post by Deleted on Jan 26, 2013 21:01:55 GMT -5
The frontside is probably the tricky part since it has the curved piece to fit into the curve of the front wall. The top length is 40-3/4, the bottom is 36" from the doorway end to the cutout for the base board. The curved piece measures 5-1/4" at the top, and 2-3/4" at the bottom, and mounts atop the bottom rail of the frame, which is 36" long. The cutout around the base is 1-1/2" X 1-3/4". The trim piece showing on the upper front measures 40" long.
Post by Deleted on Jan 26, 2013 21:04:41 GMT -5
Curved-edge piece.
Post by Deleted on Jan 26, 2013 21:07:25 GMT -5
The end toward the doorway is covered by a birch panel the same as the wall paneling. It measures 13-1/2 high by 23-3/4 long with the top corner curved off.
Post by Deleted on Jan 26, 2013 21:13:06 GMT -5
Basically the streetside frame mimics the curbside so that height and depth are the same, but in the Airflyte, the water holding tank and electrical panel are located under this frame. The front is a solid panel with the slide, rather than the large drawer the curbside frame sports.
Post by Deleted on Feb 10, 2013 18:28:57 GMT -5
The streetside framing is a bit different than the curbside in that it isn't freestanding. The rearward upright screws to the wall. It is 10-1/4" long. The cross piece measures 23-3/4 long. This part of the frame is butted up to the panel on the end of the cabinet the stove resides in.
Post by Deleted on Feb 10, 2013 18:34:25 GMT -5
The "forward" one is about the same except that the upright piece sets atop the "beam" in the front which attaches the wall panel. It is also screwed to the wall panel, and the cross piece is again 23-3/4" long.
Post by Deleted on Feb 10, 2013 18:45:36 GMT -5
The front of the streetside bench is the part that pulls it together. It is tough to make measurements that make sense, but I'll try. It measures end-to-end at the top: 41"; Top of the cutout for the beam: 38-3/8"; at the bottom in the cutout area: 36-1/4". The trim piece is 40" long. The cutout for the slider door is 16-1/4" X 8-1/4". The slider itself measures 17" X 9-1/4".
Post by Deleted on Feb 10, 2013 18:46:42 GMT -5
From the back side. Again, this is screwed to the paneling in the front end through the wall.
Post by Deleted on Feb 10, 2013 18:48:46 GMT -5
Groove for slider, and screw holes.
Post by Deleted on Feb 10, 2013 20:15:23 GMT -5
Post by Deleted on Feb 10, 2013 20:16:21 GMT -5
Benches are a wood frame with innerspring construction.
Post by Deleted on Feb 10, 2013 20:17:28 GMT -5
Hinges.
Post by Deleted on Feb 10, 2013 20:18:28 GMT -5
Hinge...with bench in sat-up position.
Post by Deleted on Feb 10, 2013 20:19:57 GMT -5
Note the cotton batting along the edges of the innersprings.
Post by Deleted on Feb 10, 2013 20:21:52 GMT -5
This "stop" is mounted under the center of the seat. It is meant to catch on the frame and keep the cushion from sliding forward.
Post by Deleted on Feb 10, 2013 20:24:10 GMT -5
Another look, showing it near the edge of the frame.
Post by Deleted on Feb 17, 2013 8:13:56 GMT -5
I was contacted by a member regarding the fact that, when the measurements are added up for the widths of the bench frames, and the table top width, they total about 4+ inches shy of the width of the camper. This means the table will not bridge the gap between the bench frames. When mine arrived home I was able to play with the different features a bit and realized this right away. Among the things that were inside were two pieces of wood, 1X3's I think, and they were long enough to span the frames. It turns out the table does not act as a part of the dinette bed, but the slats of wood make the frame across. The bench cushion construction is rigid enough to not require the solid top of the table. The cat in the photo kind of takes up the frame, but one of the slats is visible to the right, as only one of the cushions is laid down. I will attempt to find those slats and post clearer photos as soon as I can.
Post by vikx on Feb 18, 2013 0:34:07 GMT -5
What a fat black cat! Good luck for the camper...
Post by Deleted on May 10, 2013 16:11:18 GMT -5
Viola.
