Post by Shastaholics on Feb 3, 2013 11:31:41 GMT -5
I was looking at dual 5 gallon tanks for my loflyte. I'm trying to lighten the tounge load as I will already have two batteries stored on the tounge inside a diamond plate box. Has anyone else used these tanks? Besides saving all that weight, I am thinking they would look pretty nice too. I am just cooking one to two meals a day and will run a propane shower off of it for two people. Any math wizards out there that can guess roughly, how long the gas would last ? Thanks!
Post by Hamlet on Feb 3, 2013 14:22:43 GMT -5
Hamlet (a Compact) has one of the BBQ sized tanks - I think it's 20#. We have one deep-cycle battery, both mounted on the tongue. We have taken him out for as long as three weeks, cooking twice daily, showers, light and maybe tea and popcorn in the evening. We never ran out of gas. I can't imagine needing anything more. Aside from that, there was never a time that we were more than an hour or two from somewhere that we could refill the tank if we needed to.
Post by Shastaholics on Feb 3, 2013 21:08:47 GMT -5
I was thinking two 20 gallon tanks seem to be overkill and alot of extra weight. One battery will probably do the trick too. We are planning a two month trip this summer and don't want to load up the old Shasta too much.
Post by universalexports on Feb 3, 2013 23:15:28 GMT -5
I think you are a bit confused, I dont think you mean a 20 gallon tank but a 20 pound tank (as in 20 pounds of propane) here is agood link to show the different size tanks available www.tulsapowerservice.com/Tanks.html
Post by Hamlet on Feb 4, 2013 20:54:59 GMT -5
That's right universal - propane tanks are measured in pounds of capacity, not gallons. The only reasons for two tanks and two batteries is if you are planning on using the trailer as a bug-out shelter or are using it as your permanent dwelling for an extended period of time.
Post by mobiltec on Feb 4, 2013 22:15:09 GMT -5
Simple rack system. Battery box bolts to rack as does the propane tank. This is all you need really. It's also a cheap trick to post yet another photo of this trailer. ;D Attachments:
mindy
Patty Ann, 1962 Compact
Post by mindy on Apr 22, 2013 18:21:59 GMT -5
I see so many trailers with the two propane tanks and they are sitting on the nice little tray.
I have yet to attach my tank. We just carry it with us in the truck and then attach the hose to the trailer when we get there.
I would like to have it on there all the time. I have an area with two bars for it to sit on(hard to explain). Any advice on how to do this?
I also would like to paint my tank...any issues on refilling?
Post by dawgpound on Apr 22, 2013 19:49:42 GMT -5
If you could post a picture of the propane set up that you have, it would help.
As for painting the propane tanks, there are no issues with painting them....HOWEVER, do not paint the values. Just mask them off with some painters tape.
Also, if the tanks are old and haven't been used in a while, take them to a fill station and have them checked out. The tanks are only rated to be used for a certain time limit ( has to do with the welded seams) and the valves may need to be updated.
Post by youngfd on Apr 22, 2013 19:59:55 GMT -5
Mindy- Your propane tank should just sit between the bars and be bolted down. I can send pics of mine when I get back home. J
Post by youngfd on Apr 22, 2013 20:04:42 GMT -5
This shows Miss Daisy's propane tank sitting on the brackets before we started restoration. j Attachments:
