Post by swirlygirls on Feb 6, 2013 7:45:01 GMT -5
I am looking for a source for aluminum diamond pattern to use as a backsplash. The sources I see on here have lots of trim pieces and some have aluminum for a backsplash but they are all large patterns which would not look good in a little trailer. Any ideas?
Post by boandsusan on Feb 6, 2013 8:17:54 GMT -5
I intend using a small quilted diamond pattern for the backsplash on our next restore . I also noticed that all that seems available, looks too large. My plan is to buy the sheet and Bo will use a break machine at his job. Check around your area for a small fabrication shop (Metal plant). You`ll find that the aluminum will also be less expensive to purchase from them also. I`ve needed several small pieces for different projects and where my husband works, sells cut off pieces for scrap prices . Good luck!
Post by daisydunnagan on Feb 6, 2013 8:56:50 GMT -5
The Home Depot by my house has a whole bunch of different patterns (from the pillow look to the diamond) in different sizes. It can get pretty expensive though.
Post by mobiltec on Feb 6, 2013 11:46:19 GMT -5
My latest video shows quilted stainless steel that we put in as back splashes on all size trailers. We get it at a local metal shop. Anywhere that has metal fabrication going on has an outlet for all types of sheet metal. I wouldn't use aluminum because of the way it pitts around moisture. When we bought some last week it was up to $109 for a 4x4 foot sheet. Then you need to be able to cut it. Attachments:
