Post by MapleRiverShasta on Feb 14, 2013 7:22:41 GMT -5
Post by harrison429 on Feb 14, 2013 10:54:37 GMT -5
It's pretty common to see vent covers being used to hide previous holes but usually they are less conspicuous than that! What you want to look for is a louvered vent cover and then make sure to put some screening behind it to prevent bugs from entering. Attachments:
Post by cowcharge on Feb 14, 2013 11:15:07 GMT -5
Or you can use a patch inside the hole and Bondo outside.
Post by mobiltec on Feb 14, 2013 11:31:02 GMT -5
Or you can use a patch inside the hole and Bondo outside. I've done that for smaller stuff like the gouge she is talking about. But an eight inch bondo patch will crack. The aluminum skin moves a lot on the road. In that case I would patch the hole like Cowcharge says, and then cover with a louvered vent panel.
Post by cowcharge on Feb 14, 2013 11:39:11 GMT -5
Well, I have to disagree IMO, FWIW, a screen patch like they use for auto body repair, shaped to match the skin brake pattern and overlapped outside the edges of the hole on the inside of the skin, and then thickly impregnated with Bondo from both sides, will not crack. The whole repair becomes a rigid spot that doesn't flex inside of the area where the patch overlaps the edges of the hole. Worked great when I moved my water tank filler and had to fill the old hole. Not quite 8", but maybe 6". It's a little tricky sanding the brake pattern of the skin into the bondo, though.
Post by schweetcruisers on Feb 14, 2013 21:18:17 GMT -5
A patch is always going to be a patch, meaning it's always going to be visible. I suggest you take it to a small mom and pop body shop, have them make the patch panel, then have them "Panel Bond" it to the trailer.
Panel Bond is a adhesive that is made by 3M, only body shops can get it, but once cured it's permanent. It's made for fixing Uni-Body cars,
Post by vikx on Feb 14, 2013 23:53:55 GMT -5
An electrical hatch works great and gives extra storage or an outside plug... Attachments:
Post by vikx on Feb 14, 2013 23:56:17 GMT -5
Here's another style. This one opened into the closet and gave access to a plug. Attachments:
Post by vikx on Feb 14, 2013 23:57:56 GMT -5
Square the hole if it's round. You can build a little box to contain keys, wallets, etc. Attachments:
Post by vikx on Feb 15, 2013 0:01:51 GMT -5
Here's the finished trailer. Attachments:
Post by mobiltec on Feb 16, 2013 1:32:52 GMT -5
I got rid of a one foot gash by adding another baggage access door there. Just happened to be in the right spot for it. Made it a lot easier to get to stuff under the bed too because of having a door on each side. There's all kinds of ways of using or taking care of or hiding holes. 8 inches of bondo may work for someone who knows exactly what they are doing with it but I would try something else first.
Post by cowcharge on Feb 16, 2013 7:08:53 GMT -5
It's not done yet, I still have to finish sanding the brake pattern into the Bondo (my '76 has a very tricky brake pattern, yours would be simple by comparison) and paint it, and if I had a chance to redo it I would do a better job on my second try, but it works... I used the same technique to patch the hole in the roof where a tree landed. If you want to see the process, it's here, on page three, halfway down: vintageshasta.proboards.com/index.cgi?board=shastaownersrestorations&action=display&thread=648&page=3You can also keep the old vent and fill the hole with spray foam insulation... Whichever method you use, good luck! Attachments:
Post by MapleRiverShasta on Feb 16, 2013 8:33:25 GMT -5
Thanks everybody! I will let you know what I do! I like vikz's idea about putting a compartment for keys, etc. I definitely will not be putting an aluminum vent over it to hide it like they did by my water fill. I appreciate your help ;D
