Post by oldcarbuff on Mar 2, 2013 13:43:44 GMT -5
I am in the process of removing all of my windows and cleaning them, outside as well as inside trim. I recently purchased an aluminum cleaner called Gords aluminum polish and, following the directions, began to clean the trim. Seems as though it is kerosene and some form of mild abrasive. Cost is hefty and results are very poor. Purchased some of the Mothers cream polish at my local farm and fleet and results are fantastic! Suggestion to all: don't waste your dime on the Gords and you will be very pleased with the Mothers.
Post by universalexports on Mar 2, 2013 16:03:32 GMT -5
have you tried 000 steel wool, it is a miracle how fast it is and good it cleans it. Some use steel wool and vinegar, cheap, and works fast. then I will hit with with a buffing wheel and hard stick polishing compound. I've tried several of the soft rubbing/polishing compounds and nothing works on aluminum like steel wool, TRY IT! everyone on here raves about it.
Post by mobiltec on Mar 2, 2013 19:57:21 GMT -5
What kind of windows? Jalousie? I didn't like Mothers when I tried it. Now for polishing HEHR 50s windows I use a buffing wheel as well. For Jalousie windows I use a wire wheel brush for that clean satin look.
Post by universalexports on Mar 2, 2013 20:59:49 GMT -5
I heard you can use a Brass or copper (I forget) wire brush for a less course wire wheel, but I havent been able to find a brass/copper one. probably have to order it online.
Post by mobiltec on Mar 2, 2013 23:19:15 GMT -5
I heard you can use a Brass or copper (I forget) wire brush for a less course wire wheel, but I havent been able to find a brass/copper one. probably have to order it online. I've heard the same thing and had the same problem LOL...
Post by oldcarbuff on Mar 5, 2013 17:35:24 GMT -5
I have tried the 000 and like it. I have also added the use of plain kerosene and it cuts a little better. Today I tried SOS pads and water on some very dirty frames and felt it did very well. I used it on the inside frames and am extremely happy with the results then using Mother's after. Very shiny! I have to make an inside frame for a missing one and wondered if anyone has found a source for the little tube rivets which are in the corners?
Think Spring, It won't be long.
Mark
Post by mobiltec on Mar 9, 2013 23:50:20 GMT -5
I love steel wool. 0000 is perfect for turning rust into shiny...
Post by flowergirl604 on May 9, 2013 6:09:24 GMT -5
Hello- was wondering if y'all could give me some pointers about how to clean the interior and exterior window frames - but they are not removed- they are installed. When they were out to be resealed, the trim didn't get done. :/ now what is best approach?
Post by boandsusan on May 18, 2013 5:16:02 GMT -5
Hello- was wondering if y'all could give me some pointers about how to clean the interior and exterior window frames - but they are not removed- they are installed. When they were out to be resealed, the trim didn't get done. :/ now what is best approach? Same techniques,but it would be much easier and therefore quicker to remove one at a time. A wire wheel on a drill is also works wonders to remove any caulking, which was the case with all the Windows and seams on Lopo' s Frolic
Post by universalexports on May 18, 2013 12:55:11 GMT -5
I would for sure pull them out, specially if you are using a wire wheel, I'd hate for the wheel to catch an edge and make a run across an interior wall, it will do it in a flash.
Post by 62shastacrazymom on May 19, 2013 10:27:51 GMT -5
have you tried 000 steel wool, it is a miracle how fast it is and good it cleans it. Some use steel wool and vinegar, cheap, and works fast. then I will hit with with a buffing wheel and hard stick polishing compound. I've tried several of the soft rubbing/polishing compounds and nothing works on aluminum like steel wool, TRY IT! everyone on here raves about it. I am doing more of my frames today. Used the 000 Steel wool and then the buffing wheel. The hard stick polishing compound....do you just apply it and buff off? I got some at Harbor freight and am just guessing that's the logical way to do it...it is working well..
txoil
Post by txoil on May 26, 2013 9:15:00 GMT -5
Blue Magic polish also works very well on aluminum, either hand-rubbed or using an electric drill or an air die grinder with buffing bob chucked in. I am polishing all the window frames and exterior trim, and have not needed the hard stick polish/big buffing wheel (yet).
