Post by Deleted on Mar 30, 2013 10:03:46 GMT -5
I’m going to order the metal skin for my project sometime over the next week. I have no metal working experience and a mistake cutting the skin could be costly. To those of you that have installed new skin, what is the best way to cut the metal? Should it be done in place on the trailer? On the ground? What tools work best for cutting the metal cleanly and accurately? I’m especially concerned about the radiuses on the side dinette windows.
TIA for your insight.
Post by schweetcruisers on Mar 30, 2013 10:23:20 GMT -5
I bought a pneumatic shear and ended up returning it cause it damaged the metal when it would cut. The best way I found to cut it was a jigsaw with a good metal blade, and a pair of hand snips and hand shears. I did my whole trailer this way, I even looked at using a router but a good bit was almost $200.00.
Take your time, wear gloves, ear and eye protection, and a mask, aluminum dust is not really that great to breath!
I would use your old skins as templates, or you could do as I did, I put a panel up traced the roof line and window openings and then took it down and cut it on bench.
Post by mobiltec on Mar 30, 2013 22:52:07 GMT -5
I have videos on my website if you are interested. I use Hand Shears and a Razor Knife. You'll be surprised what you can do with a razor knife... Keep in mind I am folding the metal over the sides on this one and running j rail all the way front to rear. You can skip to Part 9... Watch the rear metal instalation before watching the front metal... www.cannedhamtrailers.com/57shasta.htm
Post by vikx on Mar 30, 2013 23:36:18 GMT -5
I use hand shears as well. The cuts are fairly easy, but wear gloves!
Post by mobiltec on Mar 31, 2013 13:38:14 GMT -5
If you plan on puting the front metal on the normal way with the breaks reversed, you might want to follow this video. This front was done with 6 inch breaks reversed like factory. This too is a multi-part video. www.youtube.com/watch?v=NzHHg1_I9vM
Post by Deleted on Apr 1, 2013 16:11:36 GMT -5
Thanks for the advice folks. I'll definitely take my time on that task.
Post by mobiltec on Apr 1, 2013 22:04:07 GMT -5
If you use the shears I show in my video which are available at Home Depot and MADE In the good old USA by the way. After your first attempt at cutting you will see how easy it is. Those shears are fantastic and cost about $30 with replacable blades.
