Post by shasta1flyer on Apr 10, 2013 18:38:48 GMT -5
Hello, Where is the proper placement of stand jacks under a 61 Compact? I've seen pics of jacks at the four corners but there is no trailer frame support there only wood. I see trailer frame on either side of the wheels running the width but this doesn't seem like very good placement to me. Any ideas?
thank you
Post by Deleted on Apr 10, 2013 19:17:45 GMT -5
I would like to know this, too - thanks for asking!
Post by universalexports on Apr 10, 2013 19:53:06 GMT -5
I would run a 2x4 or 2x6 under a couple of the wood frames then put the jack under that board, this would spread the load. or a 2x6 all the way across under the bottom with the jack under that. does the tongue not turn into frame under the camper.
Post by shasta1flyer on Apr 10, 2013 20:41:20 GMT -5
Thanks for the replies. Yes, the tongue turns into frame and runs up to a cross member in front of the axle. I now see a frame location at the very front of the camper near the tongue. At the back the last frame cross member is just behind the axle. Good idea about the 2x6's.
