Post by landlockt on Jun 11, 2013 22:56:22 GMT -5
A little rough on the outside. Pics make it look in better shape than it is. Here's a > link< to some pics. Everything is functioning, propane/electric fridge, propane furnace, water tank/pump, oven/stove.
Post by universalexports on Jun 11, 2013 23:30:38 GMT -5
Sweet, congrats!
Post by Hamlet on Jun 12, 2013 11:35:57 GMT -5
Congrats! It looks as though there has been paneling replaced under a window. If so, did you find out if the work behind it was done? It looks like it's all there, nice find!
Post by boandsusan on Jun 12, 2013 23:46:56 GMT -5
Congrats on your Shasta. Looks like the paneling behind the rear couch, under the rear window has been replaced or covered up as Hamlet stated. Looking at the exterior pics, I`d be tempted to lift the skin and check the framing under the rear window. Nice that it all seems to be there. Enjoy!
Post by landlockt on Jun 12, 2013 23:56:58 GMT -5
The previous owner only had it for a year or so. The owners before them did the work on it. It doesn't leak, but has in the past. There isn't a whiff of mildew or any signs of moisture and its been wet spring. I'm thinking of cleaning it up a bit but probably not a full redo. Is this model called a 16?
Post by '59PinkDeluxe on Jun 15, 2013 20:41:13 GMT -5
Wow land.... congratulations. Looks totally doable!!
Post by bigbill on Jun 15, 2013 22:55:24 GMT -5
How wide is it? It looks like my 1968 1500 if so it is 6'6" wide. The floor plan is exactly the same except my reffrigerator and furnace are in different places.
Post by landlockt on Jun 18, 2013 12:36:05 GMT -5
Mine measures 7'1" wall to wall.
