Post by Bob on Jun 13, 2013 4:19:58 GMT -5
Here's the information that I found out from my recent suspension rehah; some of it may also be relevant to other models of a similar era: Tires: ST 175/80R13 Wheels: 13”x 4 ½" wide at rim, 5 lug on 4 ½”, Center hole - 2 ½”, ¾” positive offset Studs torque to 90 -95 ft.lbs - 13/16” bolt size Hub/Drum: K-H 8444 Max Dia 10.09 Axle: 2.39” Diameter, 4” drop, 69” back plate to back plate Outer bearing: 4T-L44649, 1.063”; Inner bearing: 4T-L68149, 1.378” Grease seal: 1.72” id, 2.56” od Dust cap: 1 15/16” Axle U-bolts: torque to 70 foot pounds Springs: 3 leaf, 25 ¼” C/L of eyes, 3 ¼” arch Shackles: 3" at centerline of holes Suspension bolts: 3" long by 9/16" diameter (I used wet bolts)
machinelf
1971 1400 named Harriet
Post by machinelf on Jun 14, 2013 9:55:10 GMT -5
Thanks for posting this info!
Post by Bob on Jun 15, 2013 4:13:43 GMT -5
Glad you like it! Hopefully, as people service their axles, they can reply back with the model year that they have and if the information was accurate for them. My guess is that it’s the same for late 60’s to early 70’s model 1400s. It’ll make it easier for people to repack their wheel bearings if they already have the right grease seal ready to go.
