Ian
Trailer noob
Post by Ian on Sept 27, 2010 11:18:35 GMT -5
I'm tearing into the wiring on our "new" '66 COmpact to get the original lights to work. The original lighting isn't even connected anymore, from what I can tell.
So I really have 2 questions.
1. Does the wiring for the original lights (2 tail and 2 running) just run under the trailer? I see 3 wires poking out from the rear of the trailer that were cut. I assume if I reconnect them I'll be closer to having those lights working again.
2. Grounds. Where are the lights grounded, through the body? Which then grounds to the chassis?
I believe grounds are the biggest issue I'm facing during testing, so surprise as it's the same with old Italian cars too.
Thanks! Ian
Ian
Trailer noob
Post by Ian on Oct 2, 2010 21:00:46 GMT -5
Update: I cleaned up the ground on the frame of the trailer, reconnected the original wiring, and voila! The lights work! Now I just need to clean them up, get correct lenses for them, and reattach.
There are also aftermarket lights on the bumper that I plan to replace, as they don't match. But I got one of them working.
As with old Italian cars, it's all about the grounds!
Post by Bow_Tied on Oct 4, 2010 22:09:59 GMT -5
Congrats! Yes, the grounds are a pita, it was a cheap out to ground through the body. If I ever redo my trailer I will run grounds everywhere.
Post by Red Dirt on Oct 8, 2010 9:41:51 GMT -5
I replaced my ground wire with a heavier gauge and cleaned up the metal on the contacts and it made life a lot easier.
X2 on the cheap out, but hey, they only cut a couple corners on these old things right... ;D
Post by accomandoscucina on Feb 9, 2011 11:48:17 GMT -5
we are rebuilding a 62 with the same issues of wiring. did u end up running wires outside. it seems the original wires in ours were inside ( we gutted it to the tin). How did you make out ?
Ian
Trailer noob
Post by Ian on Feb 22, 2011 12:00:42 GMT -5
So far I've just cleaned up all the connections, put on a few new connectors, and the lights are working. A good ground on the frame is a must. If your skin is connected to the frame you'll be fine.
I just replaced the running lights this weekend, but basically just cut the old wire and crimped on the new light. I haven't tested it yet as I'm still working on the tail lights, but I'll try to get photos next time I'm out there.
