Post by adagiodream on Sept 18, 2011 20:28:03 GMT -5
I'm not an electrician...but I think I've figured out one thing about my new 1964 Shasta Compact...I'm not going to have lights when I'm camping "in the ruff". It seems that the Sweet Thing is only wired for 110. So here are my questions: How difficult is it to add a 12v system that would run from a small battery? How large a battery is necessary to run the 2 lights in the evening, a small fan in the ceiling vent and perhaps charge a phone or listen to the radio? Oh...and there are the awning lights! Could that battery be charged while my vehicle is running? Could that battery be charged by a small solar panel? How is this 12v addition made...do you recommend it? Generally...I avoid camp grounds so I'm accustomed to tent camping. The Sweet Shasta is a real step up...and I'm comfortable with propane lanterns and battery operated lights. But, I know someone out there has a few ideas for me. Thanks bunches! Lisa
Post by Gone Kayaking on Sept 18, 2011 20:52:20 GMT -5
Post by vikx on Sept 19, 2011 1:50:25 GMT -5
It's not difficult to add a 12 volt system and I recommend it. You will need one deep cycle battery, group 24, a fuse block and a battery maintainer.
Wiring must be added for each fixture. The cigar plug can go in the dinette; the lights generally go on the ceiling. A little harder to run the wires. Each needs both a hot and ground wire.
A 7 way plug on both the trailer and vehicle is necessary to charge the battery on the road.
A small solar panel will barely trickle charge the battery in full sun and will not provide enough power to run a 12 volt system.
If your awning lights are 110, an inverter will work but take a lot out of the battery. Best to save them for the Campground.
Post by vikx on Sept 19, 2011 1:55:06 GMT -5
Here is a picture of a simple system in the dinette. The battery is on the tongue. The L bracket is connecting the grounds. The orange object is the battery maintainer. Attachments:
