Post by flyingham on Mar 29, 2010 20:42:48 GMT -5
Just trying to see if anyone can read the make/model off of their potty. Mine is a Mansfield I believe maybe a 910? Anyone have an idea if this is correct? I need to order parts, and this is what I suspect at this point. Jeff
Post by dlarrow on Mar 30, 2010 11:48:07 GMT -5
Jeff, I also have a 62 16 sc. Mine has a Saniware toilet, Porcelain bowl and cast aluminum base. Not sure of the model.
Post by Atomic Addiction on Mar 30, 2010 15:59:54 GMT -5
We have a 1964 16 SC.
Ours has a Saniware toilet. The users manual in this section is from our toilet.
Post by flyingham on Mar 31, 2010 21:52:28 GMT -5
Thanks for moving this to the correct discussion!
Mine is definitely not a Saniware. Maybe it was replaced along the way. Porcelain bowl, plastic base with a flush pedal assy on the right side near the wall. Four bolt flange.
I will keep searching...
Post by flyingham on Apr 14, 2010 8:41:58 GMT -5
It appears that maybe mine was replaced with the mentioned Mansfield toilet. It is a 910. Which is the same as a Sealand 910/911. It appeared original, who knows, maybe it was. Either way, parts are easily available, and it has a four bolt flange. I put on my gloves, ignored the nasty factor of concrete hard poo stuff , and went to work. Toilet looks and works like new after repairs.
Post by Atomic Addiction on Apr 14, 2010 14:33:01 GMT -5
Jeff,
Sorry we couldn't give you more info. I'm glad it worked out for you.
