Post by persimmonpal on Mar 5, 2012 8:22:17 GMT -5
Hi All, Can anyone tell me the size tire I will need to replace those on my 1965 Compact? I am thinking of going with the bias ply as opposed to radial. Also hoped to buy whitewalls but just browsing the net they are extremely expensive. I think I will go with the whitewall paint, (if I ever get the right tires!!!) Thanks very much John
Post by vikx on Mar 6, 2012 1:40:38 GMT -5
Hi John, I don't have a 65 Compact, but make sure the wheels/tires clear the hub and wheel wells. Some of these old trailers make it very difficult to change the tires. I like the idea of bias. Your local tire shop might have a few spares to fit.
Post by mleastland on Dec 2, 2012 11:39:44 GMT -5
My 75 Compact had 185/80 /13 biased ply when I got it. They are hard to find. If you dont mind a modern spoke wheel Tractor Supply has biased or radial mounted on wheel ready to bolt on 99 for biased 109 for radial. Hope this helps.
Post by offspringin on Dec 3, 2012 8:23:51 GMT -5
I bought mine from Kaufman tire. The main tires are radials and the spare is a ply-bias (much cheaper) Of course mine is on a 70 and they are not really rounded side wall (the way a white wall would appear) so those are probably not what your looking for. There are very few options that i found even when not looking for white wall. Some places do not carry them. Others carry one style.
Mark
1961 Compact
Post by Mark on Dec 3, 2012 9:01:28 GMT -5
I've seen two restorations of 1961 Compacts that have used ST 175-80-13s.
Post by kf7grq on Feb 18, 2013 23:18:13 GMT -5
I am in the middle of purchasing a 1969 Jet 17ft trailer. The Nevada desert has turned the tires into prunes. What size tire do they take, and what is the wheel bolt pattern. I am thinking of getting tires and wheels to match the tow vehicle. Now then, if the deal does not go thru, will I be booted out of the forum?
