Post by idqrocks on Mar 18, 2012 0:16:50 GMT -5
Hello all.
I was going to rewire all the lights, but i am not sure what these lights should do. I have 2 red in the rear sides, and 2 yellow on the front sides. Shoud they just be running lights only, or do they also blink for turn signals?
Thanks!
Post by offspringin on Mar 18, 2012 0:32:49 GMT -5
mine were originally hooked up running only one wire and grounding with the skin. they only operated as running lights. when i rewired i wired them the same though i ran a ground to each light as well. you could in theory make them blink, i suppose its up to you.
can anyone else confirm or deny they are usually just running lights?
Post by vikx on Mar 18, 2012 0:53:49 GMT -5
Running lights. Would be hard to make them blink; they're run by the TM wire (tail marker) rather than the RT/LT wires....
Also, they have a single filament bulb and socket, so it's a one purpose fixture: either running lights or blinking turns.
Post by Bow_Tied on Mar 18, 2012 23:09:21 GMT -5
^ Agreed. Mine are running lights, single filament bulbs )1156). I strongly suspect this was the original intent. If you wanted it to be a signal light as well, I think the smart way would be to run extra wires and swap over to a dual filament bulb (1157)
