Post by universalexports on Jun 12, 2012 22:34:22 GMT -5
but arent those he boxes that were prone to starting fires?
Post by vikx on Jun 13, 2012 1:53:51 GMT -5
It's not the box, but failing breakers that cause the problem. And yes, they can spark and burn if the trip mechanism fails.
I have Federal Pacific boxes in some of my older trailers. We are always very careful NOT TO OVERLOAD THE SYSTEM.
If one wants to add breakers and amperage to a trailer, I don't think going with the Federal Pacific box is an option.
Be safe.
Post by joecamper on Jun 13, 2012 8:34:01 GMT -5
I could be wrong but I do not believe that putting a 30 amp main and 2 20 amp branch circutes would constitute an overload on a camper that will not have an air conditioner and was installed in a panel that is rated for 30 amp.
There is a easy way to check the opporation of the breakers.
Post by joecamper on Jun 15, 2012 20:37:33 GMT -5
Here is what the Airflyte I pulled that old panelout of is getting. Attachments:
Post by joecamper on Jun 15, 2012 20:41:42 GMT -5
It is down low front wall. 159 bucks 35 amp main + 5 a/c circutes and 6 d/c. It is also a charger and converter with a thermostaticly controled cooling fan. Probably see something similar in mnew medium sized pop-ups Attachments:
Post by joecamper on Jun 15, 2012 20:44:46 GMT -5
took a piece of salvagable original interior birchwood overcut slightly then routered around the edge. Attachments:
Post by joecamper on Jun 15, 2012 20:46:27 GMT -5
Gimped around everything Attachments:
Post by joecamper on Jun 15, 2012 20:48:40 GMT -5
Reused a bunch of original spiral nails. Turning out good looks like it was always there Attachments:
Post by joecamper on Jun 15, 2012 20:52:05 GMT -5
I had to box it out a bit more than I wanted but was nessessary for good clearence. Note the side piece of the loewr dinette at the wall Attachments:
Post by joecamper on Jun 15, 2012 20:55:30 GMT -5
replaced that with a new old piece too. Found a nice grain pattern. The inner sides of the upper kitchen cabinates are in for the same treatment. There were a few of the original ceiling panels that had to be removed for water damage around the edges that had some wonderfull looking wood grains towards the center. Attachments:
Post by joecamper on Jun 15, 2012 20:57:58 GMT -5
Here are the outlets I am using. Attachments:
Post by joecamper on Jun 15, 2012 21:01:03 GMT -5
The back clips on and off. The terminal connections are all internal and protected not outside and exposed. These are designed for r/v and are made to be put in the walls without the nessessity of putting it in a box. Attachments:
Post by joecamper on Jun 15, 2012 21:11:18 GMT -5
The faceplate clips in no fastners for a clean look. Here is one on what I built. A d/c power outletwill go there too eventually My A/C circutes will be 1 water heater 2 fridge 3 lights/outlets 4 lights /outlets 5 charger/converter D/C circutes 1 water pump 2 fantastic fan 3 sterio 4 lights 5 12 volt plug in recepticle The battery will be going directly on the other side of the wall. Outside directly against the wall between the frame as low as I dare put it. Couldnt be better. The power cord is a 30amp twistlock removable styleitsgoing in an exzisting hole street side bout 18in back from the water fill. Got some good inexpensive ideas for outide juice. Attachments:
Post by joecamper on Jun 15, 2012 21:19:22 GMT -5
Here is a pic of the outlet wired. You peel away 1in of the outer casing and skin 1/4 in of the black and white ground is already bare. Then squeeze it all in till the back clips in, You can terminate in one or go thru it as pictured. Attachments:
Post by universalexports on Jun 15, 2012 21:33:12 GMT -5
very nice work!
Post by vikx on Jun 16, 2012 1:57:30 GMT -5
It is FEDERAL PACIFIC breakers that are prone to failure, with documented fires as a result.
Most breakers have been used for years and are safe: General Electric, Siemens, Cutler Hammer, Square D, etc...
It is not a problem to upgrade to 30 amps. Just don't use a Federal Pacific box to do it.
Post by joecamper on Jun 19, 2012 20:57:23 GMT -5
Thanks for the heads up on the defective federal breakers
Post by cowcharge on Jun 19, 2012 23:21:03 GMT -5
That figures. Pretty much anything called "federal" is defective.
Post by universalexports on Nov 9, 2012 19:33:09 GMT -5
Here are the outlets I am using. where do get this type of receptical? I wounder if I can find it locally or am I stuck with ordering it online?
Post by boandsusan on Nov 13, 2012 10:03:42 GMT -5
Super nice work! Very clean and neat looking.
