Post by cowcharge on May 8, 2012 11:40:11 GMT -5
I have a '76, with the later, tiny-groove-faced window frames, instead of flat, smooth frames. 14 of them. Any tips for shining them up that doesn't involve any "Fantastic Voyage" scenarios?
Post by universalexports on May 8, 2012 14:05:53 GMT -5
I like the soft polishing wheel that goes in your drill, Ace hardware has them and as well as a good polishing compound.
Post by lopo on May 8, 2012 14:12:54 GMT -5
I just used a rag and Mother's, and a Q-tip for the corners. I did put masking tape around the windows that I didn't remove so that the black gunk wouldn't end up all over the trailer.
Post by cowcharge on May 8, 2012 14:15:21 GMT -5
I tried a kit of those stacked-cotton-circle polishing wheels that came with rouge sticks, but it didn't get into the tiny grooves and shredded itself within a couple of minutes. Is that what you mean?
Post by universalexports on May 8, 2012 17:22:26 GMT -5
maybe, sounds close, it is a wheel with cotton flappers or pieces cut and put on the wheel,
maybe a dremmel tool wheel with the cotton round things on a lower speed?
believe it or not, a chocolate bar will polish aluminum.
Post by dawgpound on May 8, 2012 18:34:02 GMT -5
Post by harrison429 on May 8, 2012 19:01:09 GMT -5
maybe, sounds close, it is a wheel with cotton flappers or pieces cut and put on the wheel, maybe a dremmel tool wheel with the cotton round things on a lower speed? believe it or not, a chocolate bar will polish aluminum. What a waste of a chocolate bar!
Post by pathfinder3081 on May 8, 2012 20:11:43 GMT -5
ROSS! Awesome man. I posted a few of these questons in my start up page.. You nailed it. And I might add without spending a $40 a pound on some mnonkey grease. I little elbow grease yeah. Some Laqure Spirits okay.. Thanks man!
Post by boandsusan on May 8, 2012 21:03:02 GMT -5
Like Ross, we use the brass wire wheel on a drill. It works great, gets into every nook and cranny.
Post by cowcharge on May 11, 2012 17:02:52 GMT -5
Great, thanks guys! I think I'll try the brass wire wheel.
Post by lopo on May 11, 2012 20:10:10 GMT -5
This ol' Florida girl just wants to clarify that "jalousie" windows are the ones that have many glass "slats," like louvers, but the windows in our 70's Shastas are called "awning" windows. This distinction might help when searching for one type or the other. Both were used in Florida in the 20th century, jalousie early and awning by the late 1950's.
