Post by franksshasta on May 11, 2010 16:52:01 GMT -5
I am in the process of cleaning up my front window and replacing all of the seals and I have run into a snag. It looks as if the side fixed windows are merely floating in a sea of black (original) sealant and clear silicone but no stops. However, I also do not see any holes where stops would have been screwed into. Were these friction fit or what. Oh and by the way, if anybody has any extra stops, I could use them. I'll post this in the parts wanted section.
Post by joek on May 11, 2010 22:10:17 GMT -5
Maybe this will help Sorry, I don't have a pic of just the stop. This is a pic when I was taking the window apart. This is the point when I am removing the side of the frame. You can see, on the left of the picture, the stop. It is a thin piece of aluminum that is bent at a 135 degree angle, adn it simply snaps into place.
Post by joek on May 11, 2010 22:16:19 GMT -5
Post by franksshasta on May 12, 2010 16:36:10 GMT -5
Has anyone ordered these stops from this company and if so, how did they work out?
