Post by atomant on May 22, 2010 10:33:20 GMT -5
I am re wiring my lights, and replacing my marker lights with VTS models. When I took off my tail lights, I discovered that they have two wires, a green and a black. The tail lights are not original, and the abackplates are in pretty good condition. They use a single bulb with two filaments. I'm considering replacing the sockets, as the corrosion is bad, and I don't want them to fail. So, here's the question-I'd like to continue to use a atwo filament bulb, and If I replcae the socket, it will be with a similar type. So, Green wire is Turn/Stop, and black is running light? So then I connect the black wire to the running light line, and the green wire to the turn signal lines? Does that sound right?
Post by atomant on May 23, 2010 14:07:14 GMT -5
Thanks vikx. So now the question is, where do Ifind the bulb sockets? I guess they are called "bayonet" type sockets, but I assumed you'd be abel to find these anywhere, and that is turning not to be the case, of course!
