Ian
Trailer noob
Post by Ian on Aug 21, 2012 13:26:38 GMT -5
Hey gang, We unfortunately broke one of the front jalousie windows on our last trip, and it took out one of the clips with it. I found a few replacement clips on Amazon or here: www.allaboutdoors.com/index.php?cPath=85_353&osCsid=8625c2318e1c5b589778658910226440but these aren't the right size. Has anybody found a source for replacement clips for our windows? I'm going to start looking for used ones, but I'm sure others need them too. I did find that getting the glass out isn't hard, and had a local glass place cut me a piece for about $10 with seamed edges. If you look carefully you can see the difference, but you have to be looking for it.
Post by dawgpound on Aug 21, 2012 13:41:49 GMT -5
Post by kto17 on Aug 21, 2012 14:01:14 GMT -5
I didn't know VTS even carried these! Thanks Ross! I need one but haven't made it far enough to need it yet.
Ian
Trailer noob
Post by Ian on Aug 21, 2012 23:28:11 GMT -5
Yup, checked there first. They're now obsolete and not available, and I assume nobody is building more. I guess if they get enough interest maybe they will, so I'll put my name on the list. It's a piece of stamped metal, not expensive to make once you make a die.
Post by dawgpound on Aug 22, 2012 6:38:49 GMT -5
Ian
Trailer noob
Post by Ian on Aug 27, 2012 22:11:23 GMT -5
Thanks Ross, I've seen those and one key dimension is off, the distance from the rivet hole to the bottom of the clip. So the glass would sit 1/2" too high. Argh.
Post by dawgpound on Aug 28, 2012 17:38:24 GMT -5
I have a small 2 pane jalousie window from an early 1960 Shasta. What is the height of the panes on your Shasta?
Ian
Trailer noob
Post by Ian on Aug 29, 2012 0:44:43 GMT -5
They are 4" tall.
Post by dawgpound on Aug 30, 2012 6:51:21 GMT -5
The panes on the small jalousie window I have are 4". How many are you needing and rights, lefts or both?
