Post by persimmonpal on Sept 20, 2012 20:51:49 GMT -5
Hi, I am trying to take off the skin of the 62 Astrodome, and I am pretty much all set.. The only thing I cant figure out is how to remove the water fill from the water tank. Any ideas?? Here are two pictures of the fill and the tank.. Also, there is a link that shows all the work I got done today. Its coming along! Thanks for any help anyone can offer!! s719.photobucket.com/albums/ww200/persimmonpal/Shasta%20Astroflyte/
Post by jbar2bc on Sept 20, 2012 22:03:29 GMT -5
I took a saws all to the water tank from the inside. My water tank had a rusted out hole hidden in the bottom. However, I am still trying to get the big bolt thing off the bottom of my water fill pipe.
Good luck!
Post by vikx on Sept 21, 2012 1:52:21 GMT -5
It takes two. Heat the threads inside the fill with a torch. Welding gloves help with unscrewing the fill. You may have to put a big pair of Channel Locks on the tank pipe inside. (2nd person)
Also, tap the pipe if you can with a brass hammer. The fill is pot metal, so be careful. If you don't have the lid, it can be split off the pipe.
Post by desertman on Oct 2, 2012 21:54:10 GMT -5
I sprayed the inside of the filler with WD40, let it set awhile and took it right off with a pipe wrench
