Post by oldcarbuff on Dec 6, 2012 19:20:43 GMT -5
My question is about the power cord used in a campground. I have not used my camper yet, but hope to as spring approaches. In going to campgrounds which supply power options, I plan to use the 30 amp service. The cable that I buy for my camper, Is is better to get one which has a straight end connector or one that has a ninety degree end? I don't have a cable yet and would like to save some frustration. What do most places have for options?
Mark
Post by universalexports on Dec 6, 2012 20:02:58 GMT -5
just from a physics standpoint I would think a 90 degree would be less inclined to fall out or get unplugged easily, less leverage from the cord, however this might make it harder to unplug when you are ready to leave as well, (no good way to pull straight out on it) if it fits really tight. I would also want to make sure it does not hang down blocking the smaller regular plug ins as well. my camp sight has a big 30 amp (weird plug) and 2 small regular plug in spots.
Post by vikx on Dec 7, 2012 0:18:15 GMT -5
I agree, the angled plug. Not sure I've seen a straight one around here....
Post by oldcarbuff on Dec 7, 2012 10:17:41 GMT -5
I was leaning toward the 90 degree but was not sure since I have never used the electrical box when camping. I think I will go with a 30ft. 90 degree. for a 30 amp service. If there is a strong feeling against this, please let me know.
Mark
Post by offspringin on Dec 7, 2012 15:21:09 GMT -5
i support your decision. I have only ran into one problem at one campground with the angled plug (i have searched for a straight pig tail connector that i could use but have been unsuccessful).
Usually the box is designed for the 90 degree plug to hang down and out of the box through holes, keeping the box shut to the weather.
This one particular campground i mentioned had the outlet so low to the bottom of the box it was almost impossible to get the plug in.
I would suggest always carrying a converter plug as well. It allows you to plug your 30amp plug into a standard 110 outlet. I believe it limits what you can run (AC etc, high draw power items) but its nice to have if its needed. Also nice to have at home when were loading at night. I just plug it in with the converter plug.
Post by oldcarbuff on Dec 7, 2012 15:42:37 GMT -5
Oh, very good point! Where would one find such a converter? What does it look like?
Mark
Post by Deleted on Dec 7, 2012 17:14:12 GMT -5
I believe you may be looking for one of these, sometimes known as a dogbone adapter. It plugs your 30-amp male end in to a 15-amp service at the campground (or home as Offspringin mentioned).
I found one listed on the website for Campingworld for under $10.
Post by oldcarbuff on Dec 7, 2012 23:33:36 GMT -5
SUPER! thanks!
Mark
Post by cowcharge on Dec 8, 2012 2:46:46 GMT -5
My camper came with an adapter that has no cord, just a round black plug with 30-amp female on one side and standard male on the other...
