Post by desjark on Jul 1, 2010 14:45:43 GMT -5
Hi all...I'm new to this site, and really like the great info sharing. I'm in the process of repairing/ restoring my 62 Shasta. I am replacing the the ceiling as the plywood is bad. I'd like to replace the cross members (3/4x2) while I'm at it. I am wondering if a 3/4 x 3 plywood would be better than solid wood. I'd like to prevent the ceiling sag. Anyone have any thoughts or ideas on this?
montanablue
Pearl the Wonder Cat
Post by montanablue on Jul 1, 2010 17:10:04 GMT -5
Buy some flat steel bar 1/2 wide and about 1/4 inch thick. Drill holes every 8 to 10 inches and use pan head stainless steel screws size 6 or 8 depending on size of hole. This will keep the spar or supports from sagging. I have pictures posted in my album in Google Gallery. This link: picasaweb.google.com/lh/photo/qLlHOHk3XNufisZGXCoEww?feat=directlinkI hope this helps. Get to it!!!! Rick
Post by desjark on Jul 6, 2010 15:46:42 GMT -5
Thanks Montanablue.....sounds like a good idea and not too heavy.
Post by staryn on Aug 8, 2010 23:05:04 GMT -5
I did a very similar thing with 1/8" aluminum strips that I had a metal shop shear for me off of a sheet of aluminum. If they have a hydraulic shear this should not be a problem for them. I left it short on one end so I could pass the romex wiring through.
