Post by tigertom22 on Feb 25, 2013 13:30:41 GMT -5
I am desperate for a 17" x 34" window window...Anyone have an idea where I might find one?
Many thanks!
Tom
Post by Deleted on Feb 25, 2013 18:24:32 GMT -5
How did you measure this window? The longest measures, outside edge to outside edge, or is this the rough opening in the trailer itself?
Post by tigertom22 on Feb 26, 2013 14:54:56 GMT -5
This is the rough opening dimensions. ... You wouldn't happen to have one would you?
Post by Deleted on Feb 26, 2013 16:11:57 GMT -5
In your '67, I am guessing these are jalousie windows and not the two-panel awning windows....
Post by tigertom22 on Feb 27, 2013 9:15:04 GMT -5
Correct. This is a jalousie window. I assume these are hard to find...
Post by vikx on Feb 28, 2013 2:46:22 GMT -5
Not hard to find, just hard to find the correct size...
Post by Deleted on Feb 28, 2013 9:42:34 GMT -5
Tom, I take it that you are replacing the window that had the A/C unit hanging in it. Is there any of the original frame left in it t measure from? (If not it should be the same as the window on the opposite side...) I have a couple that are close, but not sure they are exact. I posted photos of the two of them with the tape measure on them, here: s1178.beta.photobucket.com/user/crw2620/library/16SC%20parts%20available/WindowsMaybe you can compare them to what you have. They are both fairly decent, with the exception that someone in their lifetime put holes in them, and put carriage bolts through them to hold them onto the trailer they were on. Apparently the wooden framing rotted away to the point it could not support the windows, and that was the solution at the time. Aside from the holes, they work and even have the screen frames. Both that I have are missing one panel of the glass, but that is easily replaced, available at most hardware stores.
Post by beetle98 on Mar 6, 2013 12:10:12 GMT -5
crw2620, You had one window that measure just under 16 1/2 X 34 is that still available? I would need shipped to 28806 Asheville NC. Chad
Post by Deleted on Mar 7, 2013 9:30:10 GMT -5
@ beetle98 PM sent.
Post by beckybean on Apr 30, 2013 16:13:41 GMT -5
Chris, do you still have these windows?
