Post by camperita on Mar 25, 2013 0:54:51 GMT -5
Help! I have tried scratching through several layers of paint only to find nothing right below the gas tanks which is where the vin should be right? Anyone got an idea? I also looked on the inside on both sides. What to do? I can't get registered if they cannot verify the vin with the title.
Post by Deleted on Mar 25, 2013 20:53:15 GMT -5
It may be a little "ahead" of the tank rack, and not directly below. You have an older model too, correct? It may be on the streetside (driverside) inside the tongue frame (again ahead of the rack) on a tag attached to the frame. If it is, these tags do not stick way out and can take a little searching.
