Post by curlycat on Apr 21, 2013 19:26:30 GMT -5
We are restoring/rebuilding a 64 Airflyte. We have put galvanized flashing on the bottom edge of the side walls to prevent water from splashing up and rotting wood framing. We will be putting Tyvek house wrap prior to the siding going on. Is there a corrosion issue with the aluminum siding and galvanized flashing if this wrap is going on first?
Post by vikx on Apr 22, 2013 1:37:44 GMT -5
The aluminum doesn't like other metals. I would use duct tape before the Tyvek to be sure road vibration doesn't allow the two to touch.
