Post by cuffs216 on Jun 8, 2013 11:11:01 GMT -5
I have just removed the tiles from my Shasta and have one area that is stained with mouse urine. It appears this camper sat for a while with a family of mice living in it and the were using the drawer and floor behind the drawer as a urinal.. If some one has the cure please respond. I will be putting 1/4 subfloor over the floor to level it before new tiles go down..
This floor is solid so please don't respond with cut it out. I do not want to weaken the original structure
It is one area about 1' X 1'.. Thanks
Post by Bob on Jun 8, 2013 12:45:03 GMT -5
I put all new drawer bottoms and a couple of drawer sides and backs in mine and then (re)painted everything - the original finish was ruined anyway. I'd paint the offending areas with a stain blocking primer and then paint over that, then put your new subfloor down.
Post by iowagal on Jun 8, 2013 13:46:15 GMT -5
I like the idea of a stain blocking primer and then painting, but for a quick fix, dump a bunch of baking soda on the area, leave it overnight and then brush off. It might help you be able to stand it long enough to paint, lol. I had a situation once with some cat urine and I was amazed at what the baking soda accomplished.
Post by Deleted on Jun 8, 2013 14:13:15 GMT -5
About 4-1/2 gallons of kerosene and a good Zippo usually will work....
Oh wait...that is the preferred method while the mice are still present. Sorry for the confusion....
Post by bigbill on Jun 8, 2013 16:40:13 GMT -5
Spray it very heavy with febreez allow to dry then seal witha good primer sealer you might even soak it multiple times with febreez and get rid of it, but I would seal it anyway just for insurance. This as works on cat smell.
Post by schweetcruisers on Jun 8, 2013 17:25:29 GMT -5
Use Zinsser B.I.N. primer, it's shellac based and will seal the odor. Or if you don't want it painted white, use a couple coats of clear Shellac(don't use straight shellac on the floor, use the primer)
Post by Deleted on Jun 8, 2013 17:38:36 GMT -5
You might also try Urine Gone - that stuff will eliminate any smell, but just to forewarn you - it gets worse before it gets better. Just spray, leave it alone, and be patient for a few days. If it smells worse, that means it's working and it will go away. I think they sell it at Walgreens or Bed, Bath & Beyond.
Post by vikx on Jun 9, 2013 0:48:45 GMT -5
After all the above, use cinnamon just before laying your flooring. Doesn't take much... Also, you can re-build the drawer and replace the bottom.
