Post by LittleVintageTrailer on Aug 2, 2010 10:34:14 GMT -5
So I went to polish up the original hubs. Never really took a good look at them before. The outside is not bad but I flipped them over and yikes! Lots of rust. One is worse than the other and the rust has created a small (1 1/2 inch) hole in the side of one of them. Can these be saved? If so, how would I go about removing the rust and then repairing the hole? Also how would I seal them to prevent further rusting? Note where the white arrow is, that is the hole (more like a slice where it's rusted through. It's quite weak around that area so just a matter of time before that hole gets bigger. Kel
Post by egorspyle65 on Aug 5, 2010 0:02:45 GMT -5
Only thing you can do with those at this point is maybe Por15 the backside and paint the front. Other than that those are goners.
