Post by universalexports on Oct 7, 2012 11:12:59 GMT -5
is there a mechanical reason you need to use twist nails? I am ready to install some birtch pieces and I can find the twisty nails anywhere locally, as well a nail with a smaller head I thing would be less noticeable. Is there a purpose behind the twisty nails?
Post by Deleted on Oct 7, 2012 12:53:42 GMT -5
I suppose they won't back out as easily. For the flat head nails that are behind the trim pieces I used 11/16 carpet nails that I found ad home depot. For the exposed nails I used 7/8 twist nails that I also found at home depot. The carpet nails hold the 1/8 birch well enough that if you try to remove them you'll likely wreck the plywood. I thought schweetcruisers method of using staples was good but I didn't have a gun and didn't want to buy one.
Post by dawgpound on Oct 7, 2012 13:35:19 GMT -5
I have always used 3/4" finishing nails and a nail gun. Set the air pressure where the nail gets sunk just below the first layer of veneer of the 1/4" plywood. Then I use a color matched putty and fill in the nail hole. I have never had any paneling pull loose and out trailers have traveled from North Carolina to Connecticut and North Carolina to Key West Florida.
Post by vikx on Oct 7, 2012 23:47:45 GMT -5
I use 3/4" screws with painted heads to match the wood finish. They really grip. I also use staples at the seams, covered with trim sticks.
Post by offspringin on Oct 8, 2012 8:28:27 GMT -5
I used the 3/4 and 1" screws as well though the heads of mine were not painted. Of course i guess if your going for original that may not be the route to follow.
