Post by tigertom22 on Feb 25, 2013 10:49:25 GMT -5
I am refinishing my 67 starflyte front end and i noticed the wood in the middle - that held the table - had a metal strip screwed to the top of it.
It was also left adjusted, not in the center. Does anyone know what this was for?
Thanks!
Tom
Diana
Post by Diana on Feb 25, 2013 11:06:46 GMT -5
I dont have a clue either but my 56 trailer has the same thing.Mines about 3 foot long under the table. I thought it might be a protector for the wood from everybodys feet.
Post by kto17 on Feb 25, 2013 11:23:50 GMT -5
pictures?
Post by tigertom22 on Feb 25, 2013 13:12:34 GMT -5
I will send a pic tomorrow. But it was behind the paneling.
Very odd.
Post by boandsusan on Feb 25, 2013 19:19:03 GMT -5
We found a metal strip in our 72 Compact(rear dinette). It was 2-3 inches wide and 2.5-3ft long, aluminum. It was in the rear wall, under the paneling and above the window. Other members have mentioned a similar strap of metal but no one seemed to know what it was for.
Post by Deleted on Feb 25, 2013 20:37:52 GMT -5
I think I gotcha, Tom, but not too sure. I found this in the front of the Airflyte, a metal strip screwed tot he frame piece that the table mount is attached to from the inside. This is looking from the other way, from the outside in. It's visible in the photo but you have to know what you are looking for. It is across the top of the frame support located below the window frame. I am assuming (I know I know......) that it was originally intended to give extra torsion support to the cross member in the nose frame, and also to stiffen the support for the table to hang from, in order that it may hold up longer. There is a bunch of pressure over time from the table hanging on the front wall by 4 screws in the brackets.
Post by tigertom22 on Feb 26, 2013 14:58:37 GMT -5
Gotcha. Makes sense. I will be sure to replace!
