Post by k10lan on Apr 26, 2013 8:29:01 GMT -5
To properly fix the framing, I had to move the front window and lower half of the skin on the front of our '64 Airflyte. The skin is back on, but now I am at a bit of a loss as to how to reinstall the front window. Are the screw holes along the bottom of the opening to screw the aluminum back to the window frame, or do I put the window in first? Also, any tips on preventing leaks at the front window? This is what led to a lot of the original problems!
Thanks,
Steven
Post by boandsusan on Apr 26, 2013 10:55:46 GMT -5
We use ss staples (sparingly) to hold the skin in place around the window opening if its a long window. Clean the old putty tape off the back edge of the window and apply new putty tape. Depending on the contours of the skin, I take small pieces of putty tape and build up the low spots on the skin. Hold the window in place and use a tooth pick to poke through the screw holes in the window and line up with original holes in the skin. Hope this helps.
Post by rocknjo on Apr 26, 2013 20:08:02 GMT -5
Where does one find this putty tape? I'll be doin this soon, to most of my windows. Also having and issue with replacing the screen in the door..... How do I get the door off? to get to the screen door?
