dwstucke
1963 Shasta Airflyte
Post by dwstucke on Jun 12, 2013 20:48:28 GMT -5
Used this to cut nails holding the interior wall panels to the frame in the front and back corners. Lets you remove the front and back walls without upsetting the side walls that were installed later. Wrap hockey tape or duct tape around a 4 inch section of the blade for a handle, be sure that the teeth on the working end are pointed back so it cuts on the pull stroke.
Post by mobiltec on Jun 12, 2013 23:32:07 GMT -5
DANG GOOD IDEA! Thanks dw...
