Post by jkreighb on Jun 14, 2013 13:42:10 GMT -5
Anyone know how to remove the water fill on my 64 Astrodome?
Post by schweetcruisers on Jun 14, 2013 13:58:45 GMT -5
Is it the one for the pressurized water tank?
Post by vikx on Jun 15, 2013 1:10:18 GMT -5
If it's steel into the tank, you will probably have to get it pretty HOT. Torch it inside and out (hose nearby) and have a helper with welding gloves. Heat and try to turn, heat and turn some more. The trouble is the fill-it's pot metal and will break if not you're not extra gentle. Another option is to cut the original pipe and then remove the fill with the pipe in a vise. It's a lot safer to heat it up that way. Take care-the fills are spendy to replace...
