Post by rkymtnman on Aug 27, 2010 8:48:49 GMT -5
So I installed entirely new propane lines throughout my camper. I got everything installed, secured, and terminated. As is classic for me - I thought "I was very thorough when I installed these, I can just pressurize the system with the LP Bottle, test for leaks with a bottle of windex and fire up my appliances." (anyone see a Darwin award coming?)
I did this, found a few leaks, fixed them and everything fired up nicely. Check that off the list.
My gut nags at me for 2 days. I kept thinking I didn't test that properly. I could have tested it better. I REALLY do know better.
I finally gave in and bought the fixtures I needed and a pressure gauge. (My Test Procedure)I disconnected the regulator and connected the gauge to the rubber gas line that runs to my copper under the camper. In the back of the camper, I had already installed a "quick connect" for my road trip gas grill. To that, I attached a valve with a pneumatic nipple on each end. One end went into the BBQ connection - the other to the compressor. Charged all gas lines up to 30 psi and found 6 more leaks (using soap and water this time....) - one BIG leak in the manifold of my stove that if went undetected, very likely would have ended with a nice fireball.
I fixed everything last night, plugged all my appliances and charged it to 60 psi and it held that all night. I just reconnected the appliances and kicked it down to 20 psi and will watch that until I leave in 8 hours. It appears I have a leaky valve in my stove so that is out for this trip. Glad I found that....
Bottom line - TEST TEST TEST. Pressurize your system with air and verify it holds this pressure for at least 12 hours, if not 24. This could have been disastrous. I know I feel better after seeing that gauge at 60psi 12 hours after I charged it up.
...correct me if I am wrong but isn't the pressure AFTER the regulator down in the single digits? 60 psi would be serious overkill but I'm happy with it.
I hope my complete idiocy helps someone else. I should have (and do) known better.
Please add in your testing methods here as well. I'm interested now.
