Post by Atomic Addiction on Sept 14, 2009 15:28:31 GMT -5
When we bought our 1964 Shasta 16SC the owner had removed the rear window and frame and shoved an AC unit in there.
I pulled the AC unit and want to put a window back in there. I fear that they may have enlarged the opening to fit the AC unit. I was wondering if someone could measure their rear window to and tell me the dimensions. That way I could see how far my opening is off from the factory.
I am not sure if the rear window size changed from model to model or year to year.
Thanks for your help. Brian
chirl
Post by chirl on Sept 14, 2009 22:25:44 GMT -5
Mine is 35" frame edge to frame edge on the window, so I would guess the rough opening is about 33-33.5". I didn't measure when I had it out.
montanablue
Pearl the Wonder Cat
Post by montanablue on Sept 15, 2009 14:13:20 GMT -5
Hi, I am currently redoing my 64 Shasta 16SC from frame up. I have the rear window out and can measure the opening for you. I will try to post it late today or tomorrow. Rick
Post by Atomic Addiction on Sept 15, 2009 18:36:07 GMT -5
Thanks Chirl and Rick.
My rear window rough opening measures approximately 30" X 14.5". Not sure it that is the factory cut or not. I think it may have been cut a bit top to bottom to fit that stupid AC unit.
Let me know Rick. I gotta find a window to fit it somehow. Just need to know if the stock window is the one I need.
Post by sparky1 on Sept 17, 2009 8:40:29 GMT -5
Brian my rear window in my 66 Shasta is made by HEHR p/n= 2501A 151 235 L .the slider w/ screen is on the Left side- inside measurement = 32.5" x 15 " tall sparky1.
Post by joek on Oct 12, 2009 20:36:28 GMT -5
Post by Atomic Addiction on Oct 12, 2009 21:39:34 GMT -5
Joe,
I had considered that seller for a while. He has a posting on the Tin Can Tourist classifieds and I have been trying to figure out if that is the way I wanted to go.
I appreciate the heads up!
Post by ajknox on Nov 21, 2009 19:07:50 GMT -5
Somebody put a really ugly a/c unit in the back of my 65 shasta, which i just pulled - my window is measuring 40X15 - any ideas where I can find a replacement window?! Thanks
