Hi all
Here comes the torrent of questions now that Trailer is in hand. So I think I'm gonna go ahead and get a new axle assembly with electric brakes. Based on a couple of calls figure it will cost me around $500. Can anyone tell me what the specs would be.
You can order 3500lbs axle with e/brakes and spring kit for around $390. I think that is what I paid. I ordered it through ABCtrailer.com I'm assuming I should go with a 3500lb axle
TTH (#84) Drop 4" Spindle
Uses L68149 Inner Bearing, L44649 Outer Bearing.
10 x2 1/4 Electric brakes
But after that.....
Do I need to replace the leaf springs too, right now there are 6 leaves.... but option seems to be for 4 or 5 if I replace. And then do I want double eye or slipper?
Do I want never lube or ez lube?
ez lube What is the bolt on pattern?
It depends on the bolt pattern for the wheels you have now or if you plan on replacing them. The standard lug pattern is 5x4.5Does anyone have the dimension between the hub faces? I can get the measurement for the spring distance pretty easily. Just don't want to take everything off if I don't have to.
You need to measure from the middle of your frame rails to determine the lenght of the axle. This is how I think all measurements are taken. Then you add 16in. My measurement was 51.5in from frame rail to frame rail.And do I need to worry about the size of the axle affecting what wheel size (I have 13 in wheels) I need?
Consider me a luddite when it comes to this stuff, and be gentle, thanks!
