mcaf10
Gizmo - 1961 Nomad
Screws
May 18, 2011 21:32:48 GMT -5
Post by mcaf10 on May 18, 2011 21:32:48 GMT -5
So what kind of screwdriver/bit do I need to get for these odd shaped screws? They are screws right? Are they more oval than square? What size is the screw?
Screws
May 18, 2011 22:19:31 GMT -5
Post by Atomic Addiction on May 18, 2011 22:19:31 GMT -5
Screws
May 18, 2011 23:59:13 GMT -5
Post by vikx on May 18, 2011 23:59:13 GMT -5
The screws on my 57 Deluxe were all Robertson square drive. Most exterior were #2. I hadn't seen that before but from what I've learned, it was factory on some.
Your screws should either be Phillips or square, if they are "odd" looking and don't seem to be either, they could be "clutch head". These look like a little bow tie. They are not normally used on a vintage trailer.
Good thread above, too.
mcaf10
Gizmo - 1961 Nomad
Screws
May 19, 2011 10:31:54 GMT -5
Post by mcaf10 on May 19, 2011 10:31:54 GMT -5
All of the screws - inside and out - they all seem to be the same. It seems like they are the bow shape - not totally square Brian - thanks for the thread link on screws. I am off to Ace hardware to see if they have anything so I can start removing the benches. But here is what they look like. I added the picture to my original post -
mcaf10
Gizmo - 1961 Nomad
Screws
May 19, 2011 15:44:15 GMT -5
Post by mcaf10 on May 19, 2011 15:44:15 GMT -5
They sure are the clutch screws - just like the bow tie reference - The two bits I got will hopefully work. It seems like they are all kinda stripped with this wierd shape.
nomad
Screws
May 19, 2011 17:24:39 GMT -5
Post by nomad on May 19, 2011 17:24:39 GMT -5
Maureen, Every single screw on our trailer ,inside and out ,is a "clutch head". I guess this was the fastener of choice at the nomad factory. Your clutch head bits should work fine
