mcaf10
Gizmo - 1961 Nomad
Post by mcaf10 on Jun 3, 2011 10:42:53 GMT -5
What is the best way to get out rusted stubborn screws? Seems that I can get 25 out in a few mintues then a rusted one can take a half hour to get out.
Post by Bob on Jun 3, 2011 11:09:22 GMT -5
What kind of screws are they? I spray the difficult ones with Break Free, Liquid Wrench or some other stuff and let them sit for a while. If the head is rusted or wallowed out, I use a dremel tool with a small cutting wheel to improve the slot so that what ever kind of screw it started out as, it ends up as a flat blade. The heat of grinding on the screw head helps loosed it up too. If it's too far gone, I'll grind the whole !@#&/> head off.
Post by dlarrow on Jun 3, 2011 11:15:49 GMT -5
If the heads are big enough to keep from marring the skin, I found that using a small pair of vice grips was helpful.
mcaf10
Gizmo - 1961 Nomad
Post by mcaf10 on Jun 3, 2011 14:56:14 GMT -5
What kind of screws are they? I spray the difficult ones with Break Free, Liquid Wrench or some other stuff and let them sit for a while. If the head is rusted or wallowed out, I use a dremel tool with a small cutting wheel to improve the slot so that what ever kind of screw it started out as, it ends up as a flat blade. The heat of grinding on the screw head helps loosed it up too. If it's too far gone, I'll grind the whole !@#&/> head off. + They are the clutch screws - I will defintely get some Liquid Wrench or Break Free. Can I get that at Home Depot? I love your solution for too far gone !! I can take a lot of work frsutrations doing that ;D
Post by vikx on Jun 4, 2011 1:25:32 GMT -5
Also, getting the bit seated well in the head and tapping with a hammer sometimes helps. The screws can be almost glued to the aluminum from age and deterioration.
Recommend changing the clutch heads out for something more user friendly... good luck!
Post by dragthepaint on Jun 14, 2011 0:36:33 GMT -5
I used a grinder with a cutoff wheel to notch them, then used a flat head screw driver to get them out...worked like charm
