Post by jbar2bc on Feb 29, 2012 19:46:05 GMT -5
Hi! Sorry if this is the wrong section but is there an easy (hahaha) way to replace the wheel wells on a compact? The floor and walls are in good shape on the inside. Some of the frame on the outside is rotten and I plan to replace that. But the wheel wells are rusted pretty badly. Can anyone give advice on replacing wheel wells? Thank you! Jill
Post by offspringin on Feb 29, 2012 19:48:39 GMT -5
i believe that under the flooring they are flanged out and stapled in from the bottom. we did not pull ours but i seem to recall that's how they are. there's not much you can get to from the inside. to keep the water out its a sealed well from the bottom side. id say pull the staples and see where that gets you.
Post by jbar2bc on Feb 29, 2012 19:59:30 GMT -5
I haven't done much on the inside yet, but I guess I will start digging on the inside. Also, any ideas on where to get them made in Georgia or SC? Thank you!
Post by offspringin on Feb 29, 2012 20:09:23 GMT -5
cant help with where to get them made but i would think any kind of metal machine shop style place could accomplish the task
Post by diamondrelics on Feb 29, 2012 21:42:20 GMT -5
Mine on Coralee were flanged. My son is a metal fab guy in a street rod shop and is making me a set using my old ones as a pattern. He is using a little heavier materials since like everything else the original ones are flimsey. They might cost me $50 all together
